Return Data Set Tab
Use the Return Data Set tab to configure parameter type related values that will be returned for an event type. Only the parameters that are defined in this tab for an event template are returned in the related work order events. If no parameter is defined in this tab for an event template, no parameter will be returned for a defined event type.
Field | Use |
Parameter Type |
Select a parameter type from the list that will be returned when an ASAP event is triggered. |
Add |
Click to add a row with a default parameter type and parameter name to the Return Data Set tab in the Event Template Details area. You can add rows in the Return Data Set tab for each of the parameter types. |
Remove |
Click to clear a parameter type's related details. |
Parameter Name |
Specify a parameter name, for the selected parameter type, that will be returned when an ASAP event is triggered. |
Select |
Click to select a service action. If a service action is selected, the service action parameter in the Parameter Name will be returned only for the specific service action. If a service action is not selected and the parameter in the Parameter Name is a service action parameter, the service action parameter is returned in the event for each service action that has the parameter in the service model. |
Return Data Set |
Specify a description for the return data set. |
Related Topics
