Action Parameter Binding Editor Binding Conditions Tab
You use the Binding Conditions tab to define the conditions under which a custom binding is created. You define conditions to ensure that run-time changes to an entity initiate the execution of the correct set of technical actions.
| Field | Use |
Bindings Conditions |
Displays a list of the custom bindings in the action parameter binding. You can apply conditions to each of the bindings in the list. |
Target Data Element |
Displays the name of the target data element that is selected in the Binding Conditions list. Click Select to associate a different target element with the binding condition. |
Target Data Element Path |
Displays the relative path to the target data element. |
Binding Condition |
Enter the XPath expression to describe the condition under which the technical action is applicable to the action parameter binding. |
Related Topics
