Action Parameter Binding Editor Custom Bindings Tab
You use the Custom Bindings tab to create custom bindings, which enable you to define XPath expressions for target action data.
For example, you can bind the technical action data element to a source data element defined outside of the subject. You can create custom action parameter bindings when a subject does not contain all of the data required by the associated technical actions.
| Field | Use |
Custom Bindings |
Displays a list of the custom bindings. Select a custom binding from the list to edit the properties. |
Target Data Element |
Displays the data element defined on the technical action for which the custom binding is defined. Click Select to associate a different target data element with the custom binding. |
Target Data Element Path |
Displays the relative path to the target data element. |
Custom Binding |
Displays the binding defined for the target data element. Click into this field to edit the binding. |
Related Topics
