Action Parameter Binding Editor Binding Details Tab
You use the Binding Details tab to review binding details. For example, you can review the bindings on this tab to edit or delete invalid bindings.
| Field | Use |
Bindings |
Displays a list of the bindings. Select a binding from the list to edit the properties. Select a binding and click Remove to clear the binding. |
Contributor |
Displays the path to the source conceptual model entity. |
Source |
Displays the entity or the data element defined on the conceptual model entity for which the binding is defined. |
Source Path |
Displays the relative path to the source data element. |
Target |
Displays the simple or structured data element defined on the technical action for which the binding is defined. |
Target Path |
Displays the relative path to the target data element. |
Related Topics
