Action Parameter Binding Editor Context Tab
You use the Context tab to define the context in which the action parameter binding is to be used and to define which technical actions to include in the action family.
| Field | Use |
Subject |
Displays the conceptual model entity that contains the source data. |
Context |
Define the context in which the action parameter binding is to be used. By default, the context is defined using the relative path of the subject, and indicates that the action parameter binding is to be used wherever the subject is used. You can change the context if the action parameter binding is applicable for a more specific context. You may need to define the context more broadly if the information required by the set of technical actions must be sourced from multiple areas of a conceptual model tree. |
Action Family |
Do one of the following:
Related Topics
