Action Parameter Binding Editor Conditions Tab
You use the Conditions tab to define the conditions under which an action is created for a subject. You define conditions to ensure that run-time changes to an entity initiate the execution of the correct set of technical actions.
| Field | Use |
Action Conditions |
Displays a list of the condition name and action combinations. You can apply conditions to each name and action combination in the list. |
Action |
Displays the name of the action that is selected in the Action Conditions list. Click Select to associate a different action with the condition name. |
Action Code |
Displays the action code associated with the action selected in the Action Conditions list. Technical actions are associated with a single action code. Click Select to associate a different action code with the action. |
Condition |
Enter the XPath expression to describe the condition under which the technical action is applicable to the action parameter binding. |
Related Topics
