Action Parameter Binding Editor Bindings Tab
You use the Bindings tab to map the simple and structured data elements in the conceptual model tree on the left to the action family simple and structured data elements displayed on the right. In a simple action parameter binding, the subject contains all of the data that the action family requires.
| Field | Use |
Input |
Displays the simple and structured data elements defined for the conceptual model entity. You can select an entity, a simple data element, or a structured data element and drag the selection to a simple or structured data element in the Action Family area to bind the two selections. Binding a data element indicates that the data element defined in the conceptual model entity is the source for the target data element defined in the action family. |
Output |
Displays all of the data elements defined for all actions in the action family. Right-click a data element in the Action Family area and select Add Custom Binding to define a relative path to a data element outside of the conceptual model subject. Design Studio displays a marker next to data elements defined with custom bindings to enable you to identify those bindings quickly. All custom bindings are displayed on the Custom Bindings tab. |
Contributor from 'Before' Configuration Version |
Select to indicate the reference of previous version of the configuration. |
Related Topics
