Exporting Working Sets
You can export working sets to an external file if you want to use working sets across multiple workspaces.
To export working sets:
From the File menu, select Export.
The Export dialog box appears.
Select Oracle, and then select Design Studio Working Set.
Click Next.
Select the working sets to export.
In Select Destination, specify the path and filename for the .xml file in which to save the working sets.
If you export to an existing file, you will overwrite any content defined in the file.
Click Finish.
