Deactivating a Working Set
You can deactivate a working set to remove the filter from the workspace. You can use this option only when there is an active working set applied to the workspace.
To deactivate a working set:
From the Studio Projects view or from the Solution view, click the View Menu icon in the view toolbar.
The context menu options appear.
From the context menu list, select the Deselect Working Set option.
Design Studio removes from the Studio Projects view or from the Solution view the filter defined by all previously active working sets.
