Product Editor Derivation Tab Resource Detail Area
Use the Resource Detail area to define the component options, the cardinality, and the type of relationship the product has with each component.
Details Tab
Field | Use |
Name |
Displays the name of the component. |
Resource |
Displays the resource that the component can represent. Do one of the following:
Relationship Type |
Displays the type of relationship defined for the association. Do one of the following:
See "Defining Conceptual Model Components" for more information. |
Used By Tab
Use the Used By tab to review the projects and entities in which the component is used.
Notes Tab
Use the Notes tab to annotate entities with descriptions or with other applicable information to support the entity. For example, you can contribute content to Design Studio reports by writing your own internal documentation about entities and data elements, and you can format the documentation using plain text or simple HTML markup.
See "Notes Tab" for more information.
Related Topics
