Product Editor
Use the Product editor to model entities that represent something ordered by a customer on a commercial order.
When modeling data in the Product editor, you use some editor tabs that are common among multiple conceptual model entity editors, and you use some editor tabs that are specific to the Product editor.
When working with the Product editor, see the following topics:
