Other Relationships Tab Relationship Detail Area
Use the Relationship Detail area to associate the conceptual model entity with other conceptual model entities.
Details Tab
Use the Details tab to further define entity information.
Field | Use |
Name |
Edit the name of the target entity. |
Option |
Displays the conceptual model entities that the associated component can represent. Do one of the following:
Minimum and Maximum |
Define the entity cardinality. The Minimum field indicates the minimum number of times the entity can appear, and the Maximum field indicates the maximum number of times the entity can appear. Also, indicate whether the entity is Required or Optional or whether there can be multiple occurrences of the entity. To define a range, do one of the following:
Used By Tab
Use the Used By tab to review the projects and entities in which the target component is used.
Notes Tab
Use the Notes tab to annotate entities with descriptions or with other applicable information to support the entity. For example, you can contribute content to Design Studio reports by writing your own internal documentation about entities and data elements, and you can format the documentation using plain text or simple HTML markup.
See "Notes Tab" for more information.
Related Topics
