Adding Input Parameters to Network Integrity Processors
To add input parameters to a processor:
  1. On the Processor editor Context Parameter tab, in the Input Parameters area, click Select.
    The Select Output Parameter dialog box appears.
  2. From the list of parameters output by predecessor processors in the sequence of processors in the action, select parameters to add as input.
    Design Studio displays a warning message if there are no valid output parameters to choose from.
  3. Click OK.
    Design Studio adds the output parameters to the Input Parameters area of the current processor.
