Adding Output Parameters to Network Integrity Processors
To add output parameters to a processor:
  1. On the Processor editor Context Parameter tab, in the Output Parameters area, click Add.
    The Create Output Parameter dialog box appears.
  2. In the Parameter Name field, enter a name for the parameter.
  3. From the Parameter Type list, do one of the following:
    • Select a primitive type.
    • Click Browse and select an existing qualified Java class name.
    • Enter a valid and available Java object. This value is automatically validated to ensure that it is a valid Java object type.
    • Enter a Java generic. For example, java.util.primitive<String>.
  4. (Optional) In the Description field, add information about the parameter.
  5. Click OK.
    Design Studio generates the Request and Response Java classes.
