Adding Property Groups to Network Integrity Processors
To add property groups to a processor:
  1. On the Processor editor Properties tab, in the Property Groups area, click Add.
    The Create Property Group dialog box appears.
  2. In the Name field, enter a name for the property group.
  3. (Optional) In the Description field, add information to identify the property group.
  4. (Optional) To configure the property group as a managed property group, select the Managed check box.
    A managed property group is configurable at run time using the MBean interface. Managed property groups can contain sensitive properties.
  5. (Optional) To configure the property group as a map property group, select the Map check box.
    A map property group produces a simplified API for properties used as maps.
  6. Click OK.
    Design Studio creates the property group and adds it to the Property Groups area.
  7. Save the processor.
