Adding Properties to Network Integrity Property Groups
To add properties to property groups:
  1. On the Processor editor Properties tab, in the Property Groups area, select a property group.
  2. In the Properties area, click Add.
    The Create Property dialog box appears.
  3. In the Name field, enter a name for the property.
  4. (Optional) To configure the property as sensitive, select the Sensitive check box.
    Sensitive property values must either be left blank or be assigned to a model variable. Sensitive properties can only be contained in managed property groups.
  5. In the Value field, define the property value.
    Do one of the following:
    • To define a static value, enter the value in this field.
    • To not define a value, leave this field blank.
    • To define the property value with a model variable, select a model variable from the Model Variables list.
      Model variables allow you to set the property value at deployment time.
  6. (Optional) In the Description field, add information to identify the property.
  7. Click OK.
    The property is added to the property group.
  8. Save the processor.
