Adding Existing Characteristics to Network Integrity Scan Parameter Groups
To add existing characteristics to a scan parameter group:
  1. On the Scan Parameter Group editor Characteristics tab, right-click in the data tree area and select Select Characteristic.
    The Select Characteristic dialog box appears. The dialog box lists characteristics the current cartridge project and from dependent cartridge projects. See "Managing Project Dependencies" for more information.
  2. Select one or more characteristics from the list.
    You can filter the list by element name by typing in the Element field and clicking the Filter icon, or by entity name by typing in the Entity Name field and clicking the Filter icon. The entity name is the data schema to which the characteristic belongs.
  3. Click OK.
    Design Studio adds the characteristics to the Scan Parameter Group editor Characteristics tab.
