Defining Network Integrity Scan Parameter Group Layouts
You define layouts for scan parameter groups to specify which characteristics appear as fields in the Network Integrity UI. You can lay out how scan parameter group characteristics behave on the Network Integrity Create Scan page and on the Network Integrity Scan Details page. The same characteristic can appear and behave differently on different UI pages.
To define scan parameter group layouts:
  1. On the Scan Parameter Group editor Layouts tab, in the Page/Panels field, select the Network Integrity UI page you want to lay out.
    You can define different attributes for a characteristic when it appears on different pages.
  2. In the Panels / Elements area, select the characteristics that you want to appear as fields in the UI:
    1. From the Available list, select the characteristics.
    2. Click the Right Arrow icon to move the characteristic into the Selected list.
    Characteristics left in the Available list are still collected but are not displayed in the UI.
  3. Organize the order of the characteristics:
    1. From the Selected list, select a characteristic.
    2. Click the Up Arrow and Down Arrow icons.
  4. (Optional) To add rows, right-click a characteristic and select Insert New Row.
    Characteristics appear in the order indicated from left to right in the Network Integrity UI. By inserting a row, the proceeding characteristics restart on the left of the UI on a new row.
  5. Save the scan parameter group.
Clicking the Reset button resets the order of the characteristics in the Panels / Elements area and remove any added rows.
