Creating Network Integrity Scan Parameter Groups
To create a scan parameter group:
  1. Do one of the following:
    • From the Studio menu, select New, then select Integrity, and then select Scan Parameter Group.
    • On the Action editor Scan Parameter Groups tab, click the Add button.
    The Scan Parameter Group Wizard appears.
  2. From the Project list, select the cartridge project in which to include the scan parameter group.
  3. In the Name field, enter a name for the scan parameter group.
  4. (Optional) In the Folder field, specify a location for the scan parameter group.
    By default, Design Studio saves the entity to your default workspace. You can browse to a different location using the Browse button.
  5. Click Finish.
    Design Studio creates the scan parameter group and displays the Scan Parameter Group editor.
    If you created the scan parameter group from the Action editor, the scan parameter group is automatically added to the action.
  6. Configure the scan parameter group. See "Configuring Network Integrity Scan Parameter Groups" for more information.
