About the Characteristics Tab Context Menu for Scan Parameter Groups
The Characteristics tab context menu contains commands specific to scan parameter group characteristics. To access the context menu, right-click in the left column of the tab. The context menu options that are available depend on the selection in the editor.
| Field | Use |
Add Characteristic |
Create a new characteristic to add to the scan parameter group. |
Select Characteristic |
Add an existing characteristic to the scan parameter group. |
Delete |
Delete a characteristic. |
Refactoring |
Select to access a menu of options for improving names and locations of the characteristics. See "Refactoring Entities and Data Elements" for more information. |
Refresh |
Refresh the view. |
