Configuring Enabled Extension Points
After you create an enabled extension point, you must configure it.
To configure an enabled extension point:
In the Solution view, double-click an enabled extension point.
The Enabled Extension Point editor appears.
From the Specification Class Name list, select a Java class for the specification.
When configuring an enabled extension point for a configuration specification, you must select the InventoryConfigurationSpec Java class, which enables the Configuration Version Instance Type field to identify the configurable entity.
See "Enabled Extension Point Editor" for more information.
(Optional) If you selected InventoryConfigurationSpec from the Specification Class Name list and you want to enable the extension point for a specific configurable entity, select a configuration version Java DAO class from the Configuration Version Instance Type list. If you do not select a class, all configurable entities are enabled.
In the Point field, select an existing extension point or create a new one.
See "Creating Enabled Extension Points" for more information.
Related Topics
