Creating Enabled Extension Points
An enabled extension point associates a Java class entity specification to an extension point. You can create an enabled extension point in Oracle Communications Design Studio.
To create an enabled extension point:
From the Studio menu, select New, then select Inventory, then select Administration, and then select Enabled Extension Point.
The Enabled Extension Point Wizard dialog box appears.
From the Project drop-down list, select the project where the entity is to reside.
In the Name field, enter the name of the enabled extension point.
(Optional) Select a location for the new enabled extension point.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
