Creating Ruleset Extension Points
The ruleset extension point associates an extension point to a ruleset, and defines the placement of the ruleset.
To create a ruleset extension point:
From the Studio menu, select New, then select Inventory, then select Administration, and then do one of the following:
Select Ruleset Extension Point to associate a ruleset with a specification-based extension point.
Select Ruleset Extension Point-Global to associate a ruleset with a global extension point.
Depending on your selection, the Ruleset Extension Point Wizard or Ruleset Extension Point-Global Wizard appears.
From the Project drop-down list, select the project where the entity is to reside.
In the Name field, enter the name of the ruleset extension point.
(Optional) Select a location for the new ruleset extension point.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
