Configuring Ruleset Extension Points
After you create a ruleset extension point, you must configure it.
To configure a ruleset extension point:
Open an existing ruleset extension point or create a new one.
See "Creating Ruleset Extension Points" for more information.
In the Ruleset field, do one of the following:
Click Ruleset to create a new ruleset. See "Creating Rulesets" for more information.
Click Select to select an existing ruleset. The Ruleset dialog box appears, displaying all available rulesets.
In the Point field, do one of the following:
Click Point to create a new extension point. See "Creating Extension Points" for more information.
Click Select to select an existing extension point. The Extension Point dialog box appears, displaying all available extension points. The list displays only those extension points that are applicable to the type of ruleset extension point. For example, if you are configuring the ruleset in the Ruleset Extension Point-Global editor, only those extension points defined as global appear in the list. See "Working with Extension Points" for more information.
In the Placement field, define whether the ruleset executes before, after, or instead of the method defined by the extension point.
See "Ruleset Extension Point Editor"or "Ruleset Extension Point-Global Editor" for more information about this field.
From the File menu, select Save.
