Associating Specification-Based Ruleset Extension Points to Specifications
Ruleset extension points must be associated with an instance of a specification in order to execute. This is not applicable to global ruleset extension points (rulesets at a global extension point can execute without being associated to a specification).
To associate specification-based ruleset extension points to specifications:
Navigate to the editor of an existing specification to which you want to associate a ruleset extension point.
Click the Rules tab.
Do one of the following:
Click Select to select an existing ruleset extension point.
Click Add to create and select a new ruleset extension point. See "Creating Ruleset Extension Points" for more information. When you have completed working on the new ruleset extension point, return to the editor of the specification to which you want to associate this ruleset.
Select a ruleset extension point in the table and click Open to view the ruleset extension point in the Ruleset Extension Point editor.
Select a ruleset extension point in the table and click Remove to delete the association.
From the File menu, select Save.
See UIM Developer's Guide for more information.
