Ruleset Extension Point Editor
Use to associate a ruleset with a specification-based extension point, and to define the custom code placement.
| Field | Use |
Ruleset |
Do one of the following:
Point |
See "Working with Extension Points" for more information. |
Placement |
Define whether the ruleset executes before, after, or instead of the method defined by the extension point.
