Entity Identification Specification Editor Properties Tab
Use the Properties tab to create, select, and remove a Sequence specification. This tab also enables you to specify a prefix or a suffix for an entity specification.
| Field | Use |
Prefix |
Specify an alphanumeric sequence of characters to append to the beginning of the numeric sequence of the ID value. |
Suffix |
Specify an alphanumeric sequence of characters to append to the end of the numeric sequence of the ID value. |
Sequence specification |
Displays the name of the Sequence specification. Click to create a new Sequence specification. |
Select |
Click to select an existing Sequence specification. |
Clear |
Click to remove the association of Sequence specification. |
