Network Edge Specification Editor Related Specifications Tab
Use the Related Specifications tab to define and review specification relationships. Only relationships with the entity types listed in this tab are meaningful by default in UIM. If you add specifications to the Others section, you must define custom rulesets that trigger actions or behavior based on those relationships.
| Section | Use |
Custom Objects |
Lists specifications of custom objects that network edges based on this specification can represent. |
Networks |
Lists specifications of networks to which network nodes based on this specification can belong. |
Pipes |
Lists specifications of pipes that network edges based on this specification can represent. |
Others |
Lists specifications of entities that have a customized relationship with entities based on this specification. |
