Network Specification Editor Related Specifications Tab
Use the Related Specifications tab to define and review specification relationships. Only relationships with the entity types listed in this tab are meaningful by default in UIM. If you add specifications to the Others section, you must define custom rulesets that trigger actions or behavior based on those relationships.
| Section | Use |
Network Edges |
Lists specifications of network edges that can be included in networks based on this specification. |
Network Nodes |
Lists specifications of network nodes that can be included in networks based on this specification. |
Roles |
Lists roles to which entities based on this Network specification can be assigned. |
Others |
Lists specifications of entities that have a customized relationship with entities based on this specification. |
