Network Specifications Editor Network Configurations Tab
Use the Network Configurations tab to select, add, and remove a network configuration.
Field Use
Displays the name of the Network Configuration specification.
Cartridge
Displays the name of the cartridge project into which the Network Configuration specification is built.
Select
Click to select an existing Network Configuration.
Open
Click to open the selected configuration in the Network Configuration Specification editor.
Remove
Click to remove a Network Configuration.
Add
Click to add a new Network Configuration. See "Adding Existing Configurations to a Network Specification" for more information.
