Network Specifications Editor Network Properties Tab
Use the Network Properties tab to enter network properties.
| Field | Use |
Technology |
Select the technology for this Network specification. The Technology and Entity Type data elements are dependent on each other.
The technology is set to Undefined by default. |
Entity Type |
Select the entity type for this Network specification. The Technology and Entity Type data elements are dependent on each other.
The entity type is set to Network by default. |
Related Topics
