Pipe Specification Editor Signal Structure Tab
Use the Signal Structure tab to create a new Pipe Signal Termination Point specification or select an existing one.
| Field | Use |
Signal Structure |
Displays the name of the selected Pipe Signal Termination Point specification. Click this link to create and associate a new Pipe Signal Termination Point specification. |
Select |
Click to select an existing Pipe Signal Termination Point specification. |
Clear |
Click to remove a previously selected Pipe Signal Termination Point specification. |
