Pipe Specification Editor Capacity Required Tab
Use the Capacity Required tab to create a new Capacity Required specification or select an existing one.
| Field | Use |
Capacity Required |
Displays the selected Capacity Required specification. |
Select |
Click to select an existing Capacity Required specification. |
Open |
Click to open the selected specification in the Capacity Required Specification editor. |
Remove |
Click to remove a Capacity Required specification. |
Add |
Click to create a new Capacity Required specification. |
