Pipe Specification Editor Capacity Provided Tab
Use the Capacity Provided tab to create a new Capacity Provided specification or select an existing one.
| Field | Use |
Capacity Provided |
Displays the selected Capacity Provided specification. |
Select |
Click to select an existing Capacity Provided specification. |
Open |
Click to open the selected specification in the Capacity Provided Specification editor. |
Remove |
Click to remove a Capacity Provided specification. |
Add |
Click to create a new Capacity Provided specification. |
