Pipe Specification Editor Pipe Configurations Tab
Use the Pipe Configurations tab to select, add, and remove a pipe configuration.
| Field | Use |
Pipe Configuration |
Displays the name of the Pipe Configuration specification. |
Cartridge |
Displays the name of the cartridge project into which the Pipe Configuration specification is built. |
Select |
Click to select an existing pipe configuration. |
Open |
Click to open the selected configuration in the Pipe Configuration Specification editor. |
Remove |
Click to remove a pipe configuration. |
Add |
Click to add a new pipe configuration. See "Adding a Configuration to a Pipe Specification" for more information. |
