Activities Tab
Use the Activities tab to define and view activities in the Process specification.
| Section | Use |
Activities |
Lists the activities that have been defined for this process. The table includes activities that you define on this tab and those you define graphically in the Process Flow tab. Click Add to add an activity. Select an activity and click Remove to remove it. |
Activity |
Displays information about the activity selected in the Activities table. Click Select in the Task area to change the task associated with the activity. Click the Task link to go to the Task editor. |
