Process Flow Tab
Use the Process Flow tab to design process flows. You use a graphical palette to add activities and transitions between activities.
| Section | Use |
Canvas |
Displays activities and transitions that you have defined for the process. A Start activity appears automatically. You can drag activities to reposition them. The lines representing transitions automatically adjust to reflect your changes. Double-click an activity to open the Task editor for the Task specification associated with the activity. |
Palette |
Displays tools for adding activities and transitions to the process. Click Activity to add an activity that you associate with a Task specification. Click End to add an End activity. Click Next to add a transition between activities. |
