Task Specification Properties Tab
Use the Properties tab to define properties for the Task specification.
| Section | Use |
Duration (in days) |
Displays the estimated duration of the task. This duration is used for charting and workflow planning in UIM. |
Allowed User Group |
Limits the UIM users who can be assigned this task to members of the specified user group. |
Is Milestone |
Determines whether the task serves as a milestone in UIM. |
Checklist |
Displays the checklist associated with the Task specification. Click Select to select or change the checklist. |
