Decomposition Rule Editor
Use the Decomposition Rule editor to configure decomposition rules, which specify the conditions in which OSM decomposes one or more order components into another order component.
When modeling decomposition rules, refer to the following topics:
The following fields are common to multiple tabs on the Decomposition Rule editor:
Field | Use |
Description |
Edit the display name of the decomposition rule. |
Namespace |
Select any existing namespace or enter a unique namespace in which to include the decomposition rule. Design Studio uses the last saved namespace as the default. |
