Decomposition Rule Editor Details Tab
Use the Details tab to identify the order item specification and orchestration fulfillment patterns to which the decomposition rule applies.
Field | Use |
Order Item |
Select the order item specification to which the decomposition rule applies. OSM evaluates every order item in the source order component against the conditions that you define for the decomposition rule. If an order item passes all specified conditions, OSM includes the order item in the target order component. Click:
Fulfillment Pattern |
(Optional) Specify one or multiple orchestration fulfillment patterns to limit the scope of the decomposition rule to those order items that match at least one of the orchestration fulfillment patterns listed. If you do not specify any orchestration fulfillment patterns, this decomposition rule applies to all order items in the source order component. Click:
