Orchestration Fulfillment Pattern Editor
Use the Orchestration Fulfillment Pattern editor to describe the structure of a group of related products in a product catalog and to configure the logical sequence of steps that must be performed to fulfill order items associated with the orchestration fulfillment pattern.
The following fields are common to all of the Orchestration Fulfillment Pattern editor tabs:
Field | Use |
Description |
Edit the display name of the orchestration fulfillment pattern. |
Namespace |
Select an existing namespace or enter a unique namespace in which to include the orchestration fulfillment pattern. Design Studio uses the last saved namespace as the default. |
When configuring orchestration fulfillment patterns in the Orchestration Fulfillment Pattern editor, refer to the following topics:
