Orchestration Fulfillment Pattern Editor Details Tab
Use the Details tab to select an existing orchestration fulfillment pattern on which to base the corresponding orchestration fulfillment pattern and to identify with which fulfillment modes the orchestration fulfillment pattern is associated.
See "Orchestration Fulfillment Pattern Editor" for information about fields that appear on all Orchestration Fulfillment Pattern editor tabs.
Field | Use |
Extends |
Select an existing specification if you want the new orchestration fulfillment pattern to inherit the functionality of an existing orchestration fulfillment pattern. Inheritance by extension dictates that the contents of this fulfillment pattern's orchestration plan is augmented with the sum contents of all ancestor fulfillment pattern orchestration plans. The child fulfillment pattern includes all order components and transitions associated with parent fulfillment patterns. Do any of the following:
Default Fulfillment State Map |
Select or create the fulfillment state map that should be used as a default when creating a new fulfillment state mapping from the order component list on the Orchestration tab. See "Orchestration Fulfillment Pattern Editor Order Components Subtab" for more information. |
Fulfillment Modes |
Associate the orchestration fulfillment pattern with one or more fulfillment modes to represent the types of orders on which this product will appear. You configure the order components, transitions, and process durations for each fulfillment mode on the Orchestration Fulfillment Pattern editor Orchestration Plan tab. Do any of the following:
See "Working with Fulfillment Modes" for more information. |
Point of No Return values list |
Displays the point of no return values created for this orchestration fulfillment pattern. It also displays point of no return values inherited from other fulfillment patterns in the hierarchy established by the Extends field. Inherited points of no return indicate the entity from which they are inherited and can only be edited in the source entity. Do any of the following:
