Orchestration Fulfillment Pattern Editor Orchestration Plan Tab
Use the Orchestration Plan tab to configure the order components, dependencies, and process durations for each fulfillment mode associated with the orchestration fulfillment pattern.
The following fields are common to multiple subtabs on the Orchestration Fulfillment Pattern editor Orchestration Plan tab:
See "Orchestration Fulfillment Pattern Editor" for information about fields that appear on all Orchestration Fulfillment Pattern editor tabs.
Field | Use |
Fulfillment Mode |
A fulfillment mode denotes whether the order is intended for delivery to fulfillment systems, for testing purposes only, to request a target fulfillment system, and so forth. An orchestration fulfillment pattern can be associated with multiple fulfillment modes, each configured differently. Click the Fulfillment Mode menu to access additional fulfillment modes associated with the orchestration fulfillment pattern, and configure the order components, transitions, and process durations for every fulfillment mode listed in the menu. See "Working with Fulfillment Modes" for more information. |
When modeling orchestration fulfillment patterns, refer to the following topics for additional information:
