Decomposition Rule Editor Source/Target Tab
Use the Source/Target tab to specify the order components against which OSM will evaluate the corresponding decomposition rule, and the target order component that receives the order items that pass the decomposition rule conditions.
Source Order Components
Field | Use |
Base Components Functions Search |
Use these fields to limit the number of order components that appear in the Source Order Components area. The Source/Target tab displays all order component specifications defined in the workspace. Use Base Component to limit the display to a single root-level order component and its dependencies. Use Functions to limit the scope to executable order components (order components associated with a process). Enter a value in the Search field to search for a specific order component. |
Source Order Components |
Select the order components against which OSM evaluates the corresponding decomposition rule. OSM evaluates all order items in the specified order components. Click:
If you specify no source order components, OSM evaluates all order items associated with the order. This scenario is valid only if the target order component is produced by an orchestration stage with no dependencies. |
Target Order Components
Field | Use |
Use these fields to limit the number of order components that appear in the Target Order Components area. The Source/Target tab displays all order component specifications defined in the workspace. Use Base Component to limit the display to a single root-level order component and its dependencies. Use Functions to limit the scope to executable order components (order components associated with a process). Enter a value in the Search field to search for a specific order component. |
Target Order Components |
Select the target order component that receives the order items that pass all conditions associated with the decomposition rule. Click:
