Fulfillment State Map Mappings Tab
Use the Mappings tab to create and maintain mappings between an external fulfillment state and common project fulfillment states that are used in order and order item composition rules and point of no return rules. The mappings are based on criteria the criteria used to generate it. These criteria include: orchestration fulfillment pattern, order item, orchestration sequence, orchestration stage, and order component.
See "Fulfillment State Map Editor" for information about fields that appear on all of the Fulfillment State Map editor tabs and for information about field conventions.
Field | Use |
Filters |
Expand this section and select one or more values to constrain the mappings shown in the fulfillment state mapping table that follows. If more than one filter is specified, only entries in the table that meet all of the criteria are displayed. Note that the filter fields recognize inheritance. For example, if an orchestration fulfillment pattern of basePS is chosen in the filter, orchestration fulfillment patterns that extend basePS are also included in the resulting list. |
Fulfillment state mapping table |
Displays a list of the fulfillment state mappings that have been defined for the fulfillment state map, subject to the specified filter criteria. Do any of the following:
Mapped Fulfillment State |
Enter a fulfillment state to be assigned to the mapping's specified order item for the mapping's specified order component. |
Processing State |
Enter a processing state to be mapped to the fulfillment state. |
Fulfillment Pattern |
Enter an orchestration fulfillment pattern. This mapping only affects order components defined on orchestration plans associated with the specified orchestration fulfillment pattern. |
Fulfillment Mode |
(Optional) Select a fulfillment mode to restrict this mapping to order components defined on orchestration plans associated with the specified orchestration fulfillment pattern/fulfillment mode combination. This field is disabled until an orchestration fulfillment pattern is selected. Unlike most other fields, a new fulfillment mode cannot be created directly from the field name's hyperlink. |
Order Item |
Enter the order item specification for which the mapped fulfillment state is to be set. |
Properties |
(Optional) Select one or more properties of the selected order item specification if you want to restrict the mapping to order items with the specified property values. |
Property Value |
Select a property from the Properties list to enter a value in the Property Value field. If there is no property defined and selected, you cannot add a property value. However, if you have entered a property, you must define a value for it or the property will be ignored at run time. |
Sequence |
Enter the orchestration sequence that produces the orchestration stage that in turn produces the order components to which the mapping applies. |
Orchestration Stage |
Select one or more orchestration stages that produce the order components to that the mapping applies. This field is disabled until an orchestration sequence is selected. |
Order Component |
Select a stage in the Orchestration Stage list to select an order component that is either produced by that stage or extends an order component that is produced by that stage. The mapping only applies to this component and its descendants. Additionally, at least one of these components or its hierarchical ancestor must define an external fulfillment state. This field is disabled until an orchestration stage is selected. A new order component cannot be created from the field name's link. |
External Fulfillment State |
Enter the external fulfillment state to which this mapping applies. |
Current Fulfillment State |
Enter a common fulfillment state (optional) for the mapping to apply only if the order item already has a specific fulfillment state. |
Related Topics
