Fulfillment State Map States Tab
Use the States tab to define the fulfillment states that are used in mappings, composition rules, and point of no return rules.
See "Fulfillment State Map Editor" for information about fields that appear on all of the Fulfillment State Map editor tabs and for information about field conventions.
Field | Use |
Fulfillment States |
Displays the fulfillment state definitions that can be used in fulfillment state mappings, order fulfillment state composition rules, order item fulfillment state composition rules, and point of no return rules. Do any of the following:
Details subtab |
Edit the display name of the fulfillment state. If you are localizing OSM, use the list to the right of the field to set different values for different locales. |
Information subtab |
Enter any additional information about the fulfillment state that is required by your specific situation. If you are localizing OSM, use the list above the field to set different values for different locales. |
Related Topics
