Modeling Transformed Order Item Control Data
If you are using the order transformation manager, you need to model the ControlData/TransformedOrderItem structure in addition to the ControlData/OrderItem structure. The method for modeling this structure is different from that for modeling the regular order item structure.
To model transformed order item control data:
Enable the order transformation manager, either in the orchestration process or by adding a transformation task.
New validation errors about missing data nodes will be generated in the Problems view.
See "Orchestration Process Editor" for more information about enabling order transformation manager in the orchestration process. See "Working with Tasks" for more information about adding a transformation task.
Select any one of the validation errors relating to the missing control data, right-click on it, and select Quick Fix.
The Quick Fix window is displayed.
In the Select a fix field, ensure that Quick Fix: Add transformedOrderItem, componentKey, duration and calculatedStartDate to Control Data is selected.
Click Select All to select all of the related problems.
Click Finish.
The Add Control Data Quick Fix window is displayed indicating what actions will be taken.
Click OK.
The appropriate data elements are added to the OracleComms_OSM_CommonDataDictionary, inherited by the order, and added to the creation task for the order.
