Order Item Specification Editor Property References Tab
Use the Order Item Property References tab to map order item properties to map order item properties to specific functions.
See "Order Item Specification Editor" for information about fields that appear on multiple Order Item Specification editor tabs.
Field | Use |
Support Distributed Order Template |
Select this option to use the distributed order template for this order item. If you are using order transformation manager and this order item specification is going to be used for transformed order items, this option must be selected. For all other order items, it is optional. See OSM Modeling Guide for more information about the distributed order template and the order transformation manager. See "Referencing Items from a Distributed Order Template in XQuery Expressions" for more information about the format for referencing items in a distributed order template from XQuery expressions. |
Fulfillment Pattern Mapping Property |
Select the property that contains the orchestration fulfillment pattern for the corresponding line item. Available options include the properties you defined in the Order Item Properties field. |
Order Item Name Property |
Select the order item property that contains the name of the order item as it should appear in the Order Management UI. Available options include the properties you defined in the Order Item Properties field. The order item name is displayed in the Order Management web client wherever the order item is displayed. For example, the order item name is displayed in the Order Info region and the Orchestration Plan tab in the Order Details page. |
Requested Delivery Date Property |
Select the order item property that contains the date by which the line item must be fulfilled. Available options include the properties you defined in the Order Item Properties field. OSM uses the requested delivery date to determine processing start times and dependencies. |
Order Item Recognition Property |
Select the order item property that identifies the PSR Entity specified by the customer order line item. Available options include the properties you defined in the Order Item Properties field. This property will be used to identify the order item parameter binding and add the correct parameters to the order item specification. |
Order Item Action Property |
Select the order item property that identifies the action type of the order item. Available options include the properties you defined in the Order Item Properties field. |
Order Item ID Property |
Select the order item property that specifies a unique identifier for the order item, for example, Asset Integration ID. This property should remain the same across revisions. Available options include the properties you defined in the Order Item Properties field. |
Dynamic Parameter Property |
Select the order item property in which dynamic parameters for the order item should be stored. |
