Order Item Parameter Binding Editor
Use the Order Item Parameter Binding editor to map order item parameters to parameters on a conceptual model entity.
When modeling order item parameter bindings, see the following topics:
The following fields are common to multiple tabs in the Order Item Parameter Binding editor:
Field | Use |
Description |
Edit the display name of the order item parameter binding. |
Namespace |
Select an existing namespace or enter a unique namespace in which to include the order item parameter binding. |
Related Topics
