Order Item Parameter Binding Editor Parameter Bindings Tab
Use the Parameter Bindings tab to define expressions that will map the incoming order item parameters to parameters defined for the conceptual model entity selected on the Properties tab.
See "Order Item Parameter Binding Editor" for information about fields that appear on multiple Order Item Parameter Binding editor tabs.
| Field | Use |
Bindings |
Displays a list of the bindings contained in the current order item parameter binding. Do any of the following:
Binding |
Enter the name of the binding. You may want to have the name reflect the scope of the binding. The binding can map all of the parameters for the product, or you can define multiple bindings, each with its own XQuery. |
Binding Expression |
Enter the XQuery expression to perform the parameter binding. See "About Creating XQuery Expressions with Design Studio" for more information about entering information into XQuery controls. See "About Order Item Parameter Binding XQuery Expressions" for more information about this XQuery field. |
Related Topics
